I have installed ArduPlane v3.9.1 on an Omnibus Pro F4 v3 board and I am in the process of setting it up to install in a Bixler 3 with a GPS module. However, from what I have read in various forums, the SD card may not be supported so I won’t be able to collect log files and the OSD is not fully implemented, so I may not see the OSD information overlaid on the video stream.
Can anyone confirm if my understanding is currently accurate?
If my understanding is correct, is it known when these features might be available?
Are there any other features missing?
And, where should I look to find out what the current status of the Omnibus port is?
I’m not 100% sure about plane, but logging with the SD card works in ArduCopter (dev version). Wich means it should work in ArduPlane in think. (I have a Omnibus Pro SD V5.1 )
