I would like to ask for a feature enhancement to MP
Use case: When I flash the firmware I would like to be able to wipe the config and flash fresh
Expanded reason:
There are times when I would like to start over fresh due to some setting that was made in the FC software. The current method is to flash as something else, like plane or antenna tracker. Once that completes then the next flash is to apply the “real”.
If there was an option to wipe prior to flash, as part of the flashing procedure this would alleviate an extra step of flashing to something else.
Thoughts?
