I am adding a parameter to Sailboat in my fork intended for ‘https://github.com/ArduPilot/ardupilot/blob/master/Rover/sailboat.cpp#L104’
I am guessing the following parameter comments will break stuff due to multiline comments(/* … */). I would be interested in trying to modify whatever parses these comments to accept multiline comments in the source code. This would then make it much easier to read and comprehend the parameter comments direct in the actual source code, rather than having them run for miles off the end of the IDE/text editor window.
What do you think?
// @Param: OPTIONS
// @DisplayName: Sailboat options
/* @Description: Sailboat setup options.
Only available for separate mainsail RC channel. */
/* @bitmask: 0:TODO Mainsail works as traditional RC sail
in manual mode Range 1000 usec to 2000 usec.
1000 usec is fully sheeted in,
2000 usec is fully sheeted out */
// @bitmask: 1:reserved
// @bitmask: 2:reserved
// @bitmask: 3:reserved
/* @bitmask: 4:TODO mainsail channel modifies angle of attack
in auto, acro.
MainSailRCIn range {1000 to 1900} usec:
Sail angle of attack
=(1.0f - (MainsailChannelIn - 1000.0f)/900.0f) *
SAIL_ANGLE_IDEAL.
MainSailRCIn range {1900 +} usec:
Sail relaxed. */
// @bitmask: 5:reserved
// @bitmask: 6:reserved
// @bitmask: 7:Detect and get out of "in Irons" in AUTO mode
// @User: Advanced
AP_GROUPINFO("OPTIONS", 10, Sailboat, options, 0),
