#2 nothing happens
same when follow send by transmitter
#2 nothing happens
Does you firmware have FOLLOW_* parameters in it. You might not be running a version which supports it. Not sure what version that showed up in.
It’s ArduCopter 3.6.11, the actual version.
Those parameter settings are all good. You’ll have to ask the firmware folks why it isn’t working.
I have made another test.
Follow works if send by the transmitter.
In QGC I cannot switch to any flight mode.
After take off, flight mode is guided, selecting any other
flight mode from the menu does not change the flight mode.
Parameters download correctly and you don’t get any errors from that? Seems like the QGC->Vehicle comm direction isn’t working correctly. When you change flight mode from RC does it reflect in QGC?
Yes, parameter download does not give any errors.
Changing flight mode from RC is reflected in QGC.
I have to tap on the flight mode several times until the menu pops up.
Also the menu looks weird. After popping up it reduces its size.
This is only related to Android, the Windows version seems to work.
Ah, ok. There was a bug in the flight mode control ui which was fixed yesterday. You may be hitting that. A new daily might fix it if that’s the problem. Also I’m currently fighting with new requirements on the google play store. So best place to update latest android is from the Daily build APK link in the docs. But keep in mind you won’t get auto-update from that.
Looks better.
In version 2019-10-08 I can switch flight modes.
I haven’t flown in follow mode yet.
There is an item in the menu bar which is not fully visible.
I guess it’s Arm/Disarm.
I have just flown the quad.
Flight mode change worked.
I could switch to follow mode although it didn’t work at all.
The quad tried to attack me, lost altitude and landed.
I think this should be a firmware issue.
What was your Follow setup. Did you use the QGC Follow page to set it up? If so, can you take a screen shot of that and also a screen shot of the FOLLOW_* parameters?
Yes, those values seem valid. The drone should have stayed 8 meters above you. Which does seem like a firmware problem.
If you start QGC before you boot the vehicle it will work fine. The other way around won’t work.
It’s actually a little more specific than that. It won’t work if you start QGC and connect to your vehicle while it is already flying.
