FC output issue
Is it OK to discuss hardware issues here?
Having real issues with FC’s just giving no output to speed controller.
If not, is there somewhere else?
Many thanks.
Sure, why wouldn’t it be?
Has it worked previously? Post a flight (drive) log please and the exact model of FC and ESC.
Thank you Oli1 for replying.
This is a very long story!
I have been working on my Rover for about 18 months.
It has worked perfectly many times. I have had it working perfectly with fixed rtk positioning mowing my my fields with no problem.
Every so often it just stops working.
I am now 5 Matek F743 Wing V3 controllers and 2 Orange cubes with 4 carrier boards, numerous Receivers and 4 telemetry units down.
I have established it is not the speed controller which is an Ampflow 160 amp dual motor running no mixing.
Something is blowing up the kit.
I’m running 4.4 and have run auto tune no problem many times.
I can try and find the log when I last had a problem but that may not be possible due to to the number of logs I have.
Would a current one show where the problem lies?
@Oli1 Hi,
I have managed to find 3 logs out of many which show it when it was working nicely, one when the problems started and one where we are now.
Good Log: 00000032.BIN - Google Drive
Reversed Output: 00000039.BIN - Google Drive
No Output: 00000047.BIN - Google Drive
The No Output log was done with the Rover up on a table with the wheels in the air.
When I do the motor test C and motor test D I get no movement whatsoever now. Just beeps at the start and the end of each test.
If I plug a spare reciever directly into the speed controller the motors run fine.
Speed controller is an Ampflow 160 amp: AmpFlow Dual Motor Controller
Speed Controller Manual: https://www.ampflow.com/controllers/dual/AF160-Manual.rtf
FC: Matek H743 Wing running Ardurover 4.4
Happy to answer any questions you may have.
Cheers, Martin
