while flying in fbwb mode, climb rate was according to FBWB_CLIMB_RATE but descent rate was uncoordinated with any param.
when flying in mission planner SITL, both climb and descent rate are according to FBWB_CLIMB_RATE.
any suggestions?
- Follow the TECS tuning steps.
- Post a log demonstrating the issue.
sorry for the late response.
adding two different flights logs showing the “unhealthy” connection between the rc2in to CRt.
- I don’t see anything here other than inputs going only one way, raw baro data is pretty much useless.
- Post an actual .bin log, screenshots are pretty much useless unless the issue is extremely obvious and all relevant parameters are present.
