PVR2022
(PVR)
May 22, 2024, 6:04pm
1
Hi, thanks everyone in this community.
we have some issue in auto mode with many waypoints missions.
we have setup the wpnav_speed at 800 (8m/s), but…
now we use a missions with wp each few meters (about 40m), large missions to power lines inspection.
the problem its that with these wp distances, the drone is unable to reach the target speed. always keeps below 8m/s.
time before, we use less wp points in missions, and the target speed goes OK
at the moment, we need to use more wp points closer to get better terrain clearance.
even in MP simulation with latest firmware, the behaviour its similar.
if the distance bettween WP points are closer (about 30-40m) the drone dont mantain the target speed.
any solution? how to activate “fast waypoints” mode?
or what its the minimum distance between waypoints to consider “fast waypoints” ?
Eosbandi
(Andras Schaffer)
May 22, 2024, 6:43pm
2
What is the altitude difference between waypoints ?
PVR2022
(PVR)
May 22, 2024, 6:47pm
3
very flat mission, vertical speeds tends to 0-0,2m/s. the altitude target in wp is not the cause of these behaviour.
even in MP sitl simulation, at constant altitude wp, if the wp are very close, the target speed its unable to get
PVR2022
(PVR)
May 22, 2024, 6:48pm
4
its like there are some hidden feature that enables/disables the “fast waypoints” behaviour in function of the waypoints distance each one
Eosbandi
(Andras Schaffer)
May 22, 2024, 8:43pm
5
As long as a waypoint does not have the delay set, it is a fast waypoint.
You can increase the waypoint radius, allow the vehicle to cut corners.
Increase the yaw rate of the vehicle.
Waypoints with high-angle breaks in the route need slowing down since the vehicle cannot turn on a dime.
PVR2022
(PVR)
May 22, 2024, 9:00pm
6
yes, i understand that in corners, the vehicle have to slow down to can make the turns. there is no problem
but… i talk about waypoints in large straigh lines. if the waypoints are closer each one a distance less than 60m… the vehicle not mantain the wpnav_speed.
with waypoints separated more than 60m each other in straigh line, the fast waypoints behaviour works ok.
i have tested on sitl simulation with latest firmare.
Eosbandi
(Andras Schaffer)
May 22, 2024, 9:44pm
7
Quick fix, on the straight segments use spline_waypoints. On turns when you need precision path use normal waypoints
PVR2022
(PVR)
May 22, 2024, 9:48pm
8
thanks for the suggestion. we will try it, there could be the solution for these large straight segments on missions
therefore, in the online docs, would be appear that feature, the fast waypoints need some distance between waypoints to consider real “fast waypoints”
Eosbandi
(Andras Schaffer)
May 22, 2024, 9:51pm
9
The problem is about the acceleration/deceleration capabilities of the vehicle and look ahead of the wpnav code.
I agree that the docs need update
dkemxr
(Dave)
May 22, 2024, 10:46pm
10
I don’t know what “fast waypoints” is. I have flown missions to 38 m/s with considerations for accel, deccel, max angle, thrust/weight…
PVR2022
(PVR)
May 23, 2024, 10:24am
11
the issue is
in a large straight segment of a mission, if the distance bettween waypoints are below 60m, the drone dont reach the wpnav_speed.
if the distance are bigger than 60m, all works ok
dkemxr
(Dave)
May 23, 2024, 12:05pm
12
Sure, that seems obvious. Not really an “issue”.
