Guys, I am flying a Arducopter with GPS.
I cannot arm it after adding a GPS. The error is failsafe without no more information.
Could you help me get an idea what causes this?
No, as always, without a .bin
log file we can not.
Thanks for your response.
But without arming, I recorded nothing.
Set LOG_DISARM to 1 it will create a new log even without arming.
Here is what I just recorded
arming_fail_GPS_2.bin (853.5 KB)
Another one is arming_fail_GPS.bin - Google Drive
But this time, there is no “Failsafe” shown in MissionPlanner, but I cannot arm it either.
PreArm: RC not found
PreArm: GPS 1: Bad fix
The drone was in guided mode so it will require a GPS position. In the log I looked at the HDOP was still at 100, so I’m assuming you tested inside.
Did you have the transmitter turned on?
Hi, Allister.
For GPS.bin, I armed it inside and moved outside then I got GPS signal, but failed to arm…
For GPS_2.bin, it was begun outside with good GPS signal.
