All of a sudden, I can’t load my saved .param-files! PANIC!: “Failed to convert number, please verify your input and try again”
I’ve tried it on two different macs, same files, same message. It loops, so when hitting “OK” it just pops up again. Only way out is to force quit APM 2.0
Getting close to deep shit as the hours tick… what to do???
APM 2.0 2.0.17-33-g3d23423 daily
MacOSX 10.7.5 and an older 10.6
It’s due to having the country settings set to use , and the decimal point. Some code was added to respect the locale and it’s caused quite a few problems. I might just remove it from the build and just use .
