Frame = F550
FC = APM 2.8
ESC = 30A
Motor = XXD 2212 1000Kv
Tx = Flysky i6
As stated in the title. When I give the command to yaw left the craft will throttle up and lift. This does not happen when right yaw command is given. Any help would be greatly appreciated.
Is your barometer covered? I had an issue when it was outside in direct sunlight it would change altitude when yawing… I covered the barometer inside the apm case with open cell foam.
