F450 setup with apm2.8 is working but not lift when I increase to full throttle or half throttle . Also setup not move right or left . It stayed in the same place. I checked prop direction like this url
Also I recorded video about this issue.
For recording , video is taken inside.
When I tried outside, drone not move any direction. Same issue is happened.
How can I solve this ? Have you any idea?
Prop direction
up left : cw
up right: ccw
down left: ccw
down right: cw
My setup:
f450 frame
apm 2.8 V.3.2.1
Sİmonk 30A esc
ready to sky rs 2212-920kv.
FLysky i6 mod 1
3s 5200mah lipo
Prop are correct as far as i know . I checked above url for set this prop. Please could you check it also ?
Easy to test, is it blowing air up, or blowing air down?
I will check it.
Or it is under-powered (the copter is too heavy).
Under power mean is low battery right?
For too heavy recommendation, I can remove legs from frame . Is that meaningful solution for reduce weight? I’m using 3s 5200 mah lipo for battery.
