There are some old posts and github references to this - but I couldn’t find any answers.
Is there a way to “extract” a mission (waypoint file) from a BIN file? I can see cases where this might be useful.
Thank you!
Thank you!
No. Tlog
If you convert the .bin to .log using Mission Planner you can see the mission commands for that flight in a text editor. It’s after the parameters in the lines starting “CMD”
It’s not quite the same format as a .waypoints file but the needed information is there.
