I’m working on an autonomous boat and want to use an external heading sensor, but I’m running into issues with the autopilot actually using the heading values.
My setup is a Cube Orange+ connected to a Raspberry Pi 4 which hosts a MAVLink server and also reads data from a Garmin Steadycast heading sensor and forwards it via GPS_INPUT messages.
The Cube is mounted inside the aluminum hull of the boat and nearby the other electronics including high-power cables for the electric motors. This makes the internal compass pretty inaccurate, hence wanting to add the Garmin.
I can see with Mission Planner’s MAVLink Inspector tool that the Cube is receiving the GPS_INPUT messages and outputs GPS_RAW_INT messages mirroring the input.
However, GLOBAL_POSITION_INT messages still only reflect the Cube’s internal compass.
(I currently have the autopilot and Pi on my desk running a test script, hence the big deviation between the two readings)
Attached are the Cube’s parameters. I did everything I could think of to disable the internal compass readings and favour the heading in GPS_INPUT messages, but no luck. 2024-10-24_Cube bench test.param (15.5 KB)
Would be nice if there was a dedicated compass message from MAVLink, but I don’t have the time to develop something like that.
I just had a good look through all the documentation, Im not sure it’s actually possible to use GPS heading from a mavlink GPS. I think it should be supported, but I can’t find any documentation on that configuration.
I don’t see why it wouldn’t be possible.
There’s a GPS_TYPE option (14) for MAVLink. I’ve also added some lat/lon coordinates to my test messages so the vehicle shows up on the map, meaning it’s reading the GPS_INPUT messages just fine.
I have also changed the satellite count to 8 to see if it made a difference. It doesn’t seem to affect anything except the GPS accuracy warning.
The autopilot hasn’t complained about the GPS messages and still properly returns GLOBAL_POSITION_INT messages with the same data as in GPS_INPUT
There are quite a few checks and balances in the moving baseline driver. Simply sending GPS_RAW_INT yaw is almost certainly insufficient to mimic a moving baseline config, and if you want to fake data to that driver, you’ll have to enable it as a position source. I see you’re sending almost all 0s, which will cause a lot of compounding errors and issues.
I don’t really have any good ideas about using this data source other than writing a custom driver.
use it with a GPS, pull all the data from an actual GPS receiver so the only thing you’re spoofing is yaw.you might be able to get the GPS data from the fight controller over mavlink then package it with the yaw data.
I had that thought too, but the vehicle already has a proper moving baseline GPS setup.
The idea with the external heading sensor is to operate in environments without sufficient GPS signal for heading/intermittent signal.
Thanks for the suggestions @geofrancis. I’ve got some direction now at least.
I did try the GPS spoofing idea by copying the GPS_RAW messages from a connected GPS and using that data for GPS_INPUT messages plus the heading data, but still couldn’t get it to use the GPS heading. That could be do to a configuration issue, so I’ll keep looking into it.
In the longer-term I want to look into developing a custom MAVLink message & driver for this purpose, 'cause that would be a much cleaner solution. @Yuri_Rage Do you have any suggestions on where to start with a custom driver for the autopilot?
@geofrancis
As an update, I kept working on the GPS_INPUT spoofing and managed to get it to work.
The key was to disable HDoP in the EK3_GPS_CHECK parameter.
To summarize, it is possible to use GPS_INPUT messages to send just an external heading source but it’s a bit hacky.
The GPS_INPUT messages require fix_type of 3 or greater, and a number of visible satellites of at least AHRS_GPS_MINSATS.
It also requires HDoP to be disabled in EK3_GPS_CHECK.
Overall not a perfect solution, but it’ll work for the time being.
I think a MAVLink compass message/driver would be a worthwhile addition for projects like mine.
