I have been using an M8N GPS/Compass combo on my Arduboat mounted outside the hull in a waterproof box. The Arduboat is too large to calibrate the compass by rotating the entire vehicle and removing the M8N connector multiple times has caused slop in the connector.
I would like to mount the M8N GPS receiver and compass inside the hull and route a waterproof GPS antenna outside via a coax cable. I can either use a combo GPS/Compass or separate the GPS Rx and I2C compass.
jDrones has what I need but is out-of-stock so I’m looking for a similar product
GPS w/ external antenna
http://store.jdrones.com/jDrones_NEO6_Airplane_Rover_GPS_p/jdneo6v10b.htm
GPS/Compass combo with external antenna (out of stock)
http://store.jdrones.com/jDrones_NEO6_PlaneRoverBoat_GPS_Compass_p/jdneo6magb.htm
Standalone External Compass (out of stock)
http://store.jdrones.com/Pixhawk_ExtCompass_HMC5983_p/jdmagneto02.htm
