Extensions in Mavlink
Hi all,
I’m trying to send custom data in “mavlink_msg_servo_output_raw_send” by replacing v[8]-v[15] in to my custom data but I keep getting 0 in this values shown in mission planner.
I noticed that all the v[8]-v[15] of SERVO_OUTPUT_RAW in common.xml are “extensions” but from what Iv’e read here - Handling message extensions I still should see those fields.
Why I cannot see those and how can I fix it without re-generating this message?
Arducopter: 3.5.0-rc4
MissionPlanner: 1.3.52
Thanks, Gal
You need to switch to mavlink2 in order to make those messages work.
Futhermore you will need to see if the source code supports those extensions.
How do I switch to mavlink2?
Just by changing the SERIAL*_PROTOCOL parameter?
First hit on google:
http://ardupilot.org/copter/docs/common-telemetry-port-setup-for-apm-px4-and-pixhawk.html
