I know when you geotag images using dataflash the csv file shows Speed Direction Tilt Yaw and Roll is this data automatically assigned to the geotagged images? If so how do I access this data if I go into properties for the image I only get Lat Long and Hgt.
Also I’m using Here3 for RTK and if I tick the use GPS Alt box the images are tagged for my current location at 200m (+/- slight variation) when the actual height AGL is 80m I assume that if I’m to do this method I should add a relative base ALT on the Georeferencing page. I just left all the ALT information unchecked and the HGT data appeared to be ok…but is there a best practice?
