Flying with just the FMU is not officially supported (it is not part of our testing) but as you say it has been working. I think we overlooked this in 3.1 and the problem is you can’t arm. This should be resolved in master.
That should allow you to arm and the motors to spin.
Be very cautious if you actually fly master. There are some known issues with the throttle pulsing and a massive wobble at waypioints during missions, but please report back if you can arm.
Hello @Craig3DR,
I tried your manual but still the same problem: there is no PWM-output from the multi-connector.
Another point I found: the commit from firmware version 13.12.2013 02:12 (first version that is no more working with px4fmu) says:
“PX4: added automatic IO firmware update
this avoids the px4io.loaded file on the SD card that confused many users”
So I tried to put an empty file with name “px4io.loaded” on the SDcard and ESC’s become active! But at some later version this does not work anymore.
