Are temp logs in C or F?
I’m also wondering what would cause this
This is a BLHeli32 4 in 1 ESC. When I look at the ESC after a flight with my IR cam it’s about 120f.
As you can see here: https://github.com/ArduPilot/mavlink/blob/master/message_definitions/v1.0/ardupilotmega.xml#L1703
the temperature is in °C
@peterbarker gets the cookie:
temps will only go up to 127oC
Thanks for the help!
