I try to add telemtry for my ESC, everything works fine, I got all value volt, rpm, temp but current is always at 0, when I try a motor test I have always 0 for current is it normal ?
I have exactly the same view that the tuto
Hi, how did you connect esc to flight controller for esc telemetry I am using t-motor f35a 3-6s esc I need rpm data for dynamix notch filter can you help me
First determine if you can run Bidirectional Dshot firmware with the Flight Controller you are using. Then there is no additional connection for RPM and it’s a better source than serial port telemetry for the notch filter. Otherwise there is a wealth of information on the Wiki: ESC telemetry
There is a “T” pad on those ESC’s. Tie them all together, connect to the Rx of a serial port and configure that port for ESC telemetry.
