As per manual provided by the manufacturer, Tmotor Thunder 300A ESC supports UART TTL output of telemetry data
Adopt three wire UART DATA postback, signal wire definition in sequence: ground wire,
signal wire, power wire(3.3-5.0V), baud rate 38400bps, character mode
Data package format:SPD:XXXX TMOS:XXXX TMOT:XXXX TMCX:XXXXXXXXXXXX
CURI:XXXX VOLT:XXXX PWAC:XXXX SYS:XXXXXXXXXXXX
DBG:XXXXXXXXXXXX。
SPD:XXXX RPM
TMOS:XXXX ESC temperature(℃)。
TMOT:XXXX Motor temperature(℃,retention data)。
TMCX:XXXXXXXXXXXX (debug retention data)。
CURI:XXXX Motor current( X 0.01 A) 。
VOLT:XXXX supply voltage( X 0.01 V) 。
PWAC:XXXX Power Ripple(ebug retention data) 。
SYS:XXXXXXXXXXXX (ebug retention data) 。
DBG:XXXXXXXXXXXX (ebug retention data) 。
Here is the PDF file of the manual
thunder_300a_esc_manual.pdf (102.5 KB)
Is this format same as BLheli32 output format ? I have tested this ESC on GPS2 port (serial4) with the protocol set to 16 but there was no data in the status tab in mission planner.
Is there some other way I can make the ESC telemetry work for all 4 motors ?
Thanks,
MindProbe
