Awesome @Rolf That did the trick.
Thanks to both of you for helping out it’s greatly appreciated.
Now if I could just find out why the rudder doesn’t move in Q Stabilize while the other control surfaces do the last mystery will be solved. At least till the next ones come. lol
Oh I need to see if the 5th motor shows up in motor test. I didn’t check that.
Edit:
I checked it made no difference to the motor test interface. Still only 4 motors.
I now think I need to mess with ESC calibration next. But I am slowly moving forward.
Thanks @geofrancis
I got the telemetry to work. I just didn’t have the config done correctly.
works great now.
I am left with 2 questions.
Should the motor test interface show the pusher motor and allow you to test it. I don’t se it so I don’t’ know if that’s normal.
Second I notice that the rudder doesn’t move it Qstab but the aileron and elevator. do move. If I change to FBWA then the pusher motor runs and rudder works …so not sure whats up.
Thanks Man.
I suspected that was the way it is…but I couldn’t find any documentation that stated it.
I appreciate you letting me know.
Now if I can just get the ESC calibration to work right I think I will be ready to install the power systems into the machine.
