I have built a 7" quad (AOS UL7 with Matek H743, Tekko 32 F4 Metal 4in1 65A ESC and had a few preliminary and successful flights in Stabilize, AltHold and even rock solid PositionHold in 7 mph winds. I cannot figure out why I am not getting the current (Amp) reading from the ESC?
I do get an accurate voltage reading and also RPM, Temperatures and voltage of each ESC but not current. below are the settings I have used:
SERIAL5_PROTOCOL 16
SERVO_BLH_TRATE 10
SERVO_BLH_POLES 14
BATT_MONITOR 9
SERVO_BLH_AUTO 1
SERVO_BLH_MASK 15
MOT_PWM_TYPE 1
SERVO_DSHOT_ESC 1
If I change BATT_MONITOR 4 then I loose the individual RPM and Temp. readings from the ESCs. The Tekko 32 F4 supports telemetry on each motor via Dshot. I tried the BATT_MONITOR 4 and I am getting false readings; see below
