Hi.
I am building quadcopter drone, my Esc continue beeping and no error on the screen.
I tried calibrating the Esc with no luck.
- Esc: is hobbywing pro 60A
- Herelink unit
How do I go about solving this issue?
Hi.
I did try this, with no luck.
First let’s put this in the proper thread not Arduplane. Done.
Post your parameter file. And which ESC exactly?
I don’t see anything in the parameters file that would cause a problem. It’s configured for standard PWM which those ESC’s are. I would guess a connection problem.
Thanks @dkemxr I checked the connection. The issue was with my PDB. Now everything is sorted,
