Esc brushed motor test nothing work?
hello everyone
I’m testing with
pixhawk 5x, radio MK15 ardurover V4.5.1 with mission planner
motors DC12V 15W 500RPM 37GB555 Mini High Torque Gear Motor
480A Brushed ESC Single Motor with Cooling Fan Waterproof 2-4S 3 Modes 5V/3A BEC for RC Cars
config servo out put 1 (value 73) 3 (value 74)
I can’t do the motor test
the esc flashes
what should I do in the configuration?
THANKS
Is the ESC configured for Forward/Reverse? You are trying with Test Motor C&D with increasing throttle percent? Set the throttle to ~30% and the Duration for ~30 sec. Hit Test All Motors and then flip over to the Servo Output Screen and see if 1 &3 have increased from 1500.
hello
yes esc configured forward/reverse
I couldn’t do the esc calibration ?
I removed the red wire from PWM 1 and 3 to keep signal and ground it’s ok
test motor 30% nothing
esc calibration : type normal it’s ok for my esc brushed ?
hello
I just found the problem
the connection of the esc outputs was on aux and not on main
so test motor servo out 1 ok the right motor works
but no servo out 3 nothing
