HI!
I just made first attempt to connect ESC telemetry to Arduplane 4.0.6 and it doesn’t work as well as for Craig F. I have Pixracer FC, ESC R Fly Fort with BLHeli 32 V32.6. PPM is connected to Servo3 and I can configure ESC through FC. Telemetry out is connected to RX of Telemetry2 (Serial2) port, SERIAL2_PROTOCOL 16, speed 115200. Does anyone know what to do?
Thanks!
Roman
Edit: It seems I found it: I enabled “auto telemetry” in the ESC settings and it started working. @craigy72 Try the same and let me know, if that worked for you.
Roman
Hey Roman, thanks for this. I did try this actually and it didn’t work for me. It seems that there is definitely a bug with the 405 build as I have a 765 and it works fine on that FC.
Are you able to give me all of your settings and I will try the same. Be interested to see your SERVO_BLH_ settings
I’m bit confused what do you mean with bug in “405” because my Pixracer has F405 CPU and it’s now working on it - see here: https://drive.google.com/file/d/1j7DLr7B9h8wvc067_rv7vm3qR7JMcCmZ/view?usp=sharing
Are you sure you don’t have serial port numbering or RXD/TXD pin mismatch? On some targets is serial port numbering quite confusing and some wiring diagrams shows not RXD/TXD label of the actual pin, but where it should be connected to (which is the opposite). Check that once more…
Good luck!
