Please I need to solve this problem. I’ve been unable to ‘Write’ my flight plan to the APM from the Mission Planner. After designing my flight plan, I try to Write it by clicking on the Write Tab on & I get an error with the following details… I took a screen shot of the error message… Please find attached the screen shot
I noticed your wp radius are big, overlapping with the radius of other wps, reduce the radius.[/quote]
I just created a new flight plan with your advice & I noticed same Error but different details. from the 1st error it says; Timeout on read - setWP but after creating the new flight plan it says;Timeout on read - setWPTotal with different details. find attached a screen shot of the new error with the details
[quote=“meee1”]asking for more data than the link can provide.
does it work over usb?[/quote]
Well the APM has a USB port so also the 3DR radio, its a version2. I actually have both versions 1 & 2, 900mhz radios. The base station (that’s the one connected to the computer via USB) is a version 1 while the other connected to the APM is a version 2. The initial radio connected to the APM on the drone is bad so I replaced it with a version 2. Now what do you mean by “does it work over usb?” ?
