I intend to use openCV in Mission Planner Scripts. I have tried to import it using the import cv2 method, but it did not work. I also tried using the OS library to change the working directory to import cv2, but it gave me the following error:
Object reference not set to an instance of an object.
So can anyone please tell me if there is a way to have openCV working with Mission Planner?
Fantastic! After I found out that ironPython does not support opencv I turned to dronekit and I am still working on it. Actually I’m quite intrested in your solution. It would be great if you can share your ideas.
