Error while creating signed bootloader for omnibusf4
i need help to resolve this error. i was creating bootloader and signed firmware for board name " Omnibusf4" but when i tried to sign it i got the following error:
[212/224] Compiling Tools/AP_Bootloader/bl_protocol.cpp
[213/224] Compiling Tools/AP_Bootloader/md5.cpp
[214/224] Compiling Tools/AP_Bootloader/can.cpp
[215/224] Compiling Tools/AP_Bootloader/network.cpp
[216/224] Compiling Tools/AP_Bootloader/custom.cpp
[217/224] Compiling Tools/AP_Bootloader/flash_from_sd.cpp
[218/224] Linking build/omnibusf4pro/lib/libAP_Bootloader_libs.a
[219/224] Linking build/omnibusf4pro/Tools/AP_Bootloader/liblibcanard.a
[220/224] Linking build/omnibusf4pro/bootloader/AP_Bootloader
/opt/homebrew/Cellar/arm-none-eabi-gcc/10.3-2021.10/gcc/bin/…/lib/gcc/arm-none-eabi/10.3.1/…/…/…/…/arm-none-eabi/bin/ld:common.ld:202 cannot move location counter backwards (from 0000000008006900 to 0000000008004000)
collect2: error: ld returned 1 exit status
Waf: Leaving directory `/Users/anshadlakha/ardupilot/build/omnibusf4pro’
Build failed
→ task in ‘bootloader/AP_Bootloader’ failed (exit status 1):
{task 4403132272: cxxprogram AP_Bootloader.cpp.7.o,bl_protocol.cpp.7.o,can.cpp.7.o,custom.cpp.7.o,flash_from_sd.cpp.7.o,md5.cpp.7.o,network.cpp.7.o,support.cpp.7.o → AP_Bootloader}
(run with -v to display more information)
Build failed: ./waf bootloader
Failed boards: [‘omnibusf4pro’]
Note: i tried changing the Hal storage size and flash reserve size but nothing worked. if i create normal bootloader(without signing it with public key) it works normally but as soon as i try to sign it i get the error.
@Zerocool
Is there any solution you get?
I am facing a similar kind of problem.
