I get the following error while trying to compile SITL for ArduPilot. I’ve followed the instructions on how to run it on Windows available on the webpage 1.
I’d appreciate if somebody could give me a hand on this.
Do not use make sitl -j4
use .\waf copter
instead
I’ve found the error: had forgotten to run
git submodule update --init --recursive
correctly.
update your git sub modules in proper folder/location.
The recommended thing to is is run “sim_vehicle.py” from the Vehicle directory (like in /ArduPlane or in /ArduCopter) and it will handle all the submodule stuff
Hello I am also having the same problem, I want to simulate plane not copter, I used your command what you said with modification, but it give me error
bash: .waf: command not found
Please help me.
You need to follow the instructions on the ardupilot.org website and install a couple of packages in your computer first.
On windows:
or on linux:
and .waf
is wrong. It has to be ./waf
on linux or .\waf
on windows.
