I am going through the guide for setting up the build environment for linux/ubuntu. And I get an error regarding pygame when I run the script /install-prereqs-ubuntu.shβ¦
I am not able to install pygame using pip either. Does anyone have any clue to what I might be missing?
Thanks,
krisaue
Hardware: Nvidia Jetson Nano
Software: Ubuntu 18.04
ERROR OUTPUT:
Collecting pygame
Using cached pygame-2.0.1.tar.gz (5.5 MB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-fgwv7W/pygame/setup.pyβ"β"β; file=β"β"β/tmp/pip-install-fgwv7W/pygame/setup.pyβ"β"β;f=getattr(tokenize, β"β"βopenβ"β"β, open)(file);code=f.read().replace(β"β"β\r\nβ"β"β, β"β"β\nβ"β"β);f.close();exec(compile(code, file, β"β"βexecβ"β"β))β egg_info --egg-base /tmp/pip-pip-egg-info-_Pj2qA
cwd: /tmp/pip-install-fgwv7W/pygame/
Complete output (29 lines):
WARNING, No "Setup" File Exists, Running "buildconfig/config.py"
Using UNIX configuration...
sh: 1: sdl2-config: not found
Hunting dependencies...
For help with compilation see:
https://www.pygame.org/wiki/CompileUbuntu
To contribute to pygame development see:
https://www.pygame.org/contribute.html
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-install-fgwv7W/pygame/setup.py", line 318, in <module>
buildconfig.config.main(AUTO_CONFIG)
File "buildconfig/config.py", line 221, in main
deps = CFG.main(**kwds)
File "buildconfig/config_unix.py", line 194, in main
DependencyProg('SDL', 'SDL_CONFIG', 'sdl2-config', '2.0', ['sdl']),
File "buildconfig/config_unix.py", line 39, in __init__
self.ver = config[0].strip()
IndexError: list index out of range
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
