Hi All,
I am having a problem trying to build ardupilot code using make for windows tutorial.http://dev.ardupilot.com/wiki/ez-building-apm2-with-make-in-windows/. I am not sure whether it is a filepath issue or something else. I have been looking at a few other online sources with similar problems. I tried a few possible solutions but have still been running into this problem. Here is a link to one such issue with a solution https://groups.google.com/forum/?nomobile=true#!msg/drones-discuss/YooljrxL36A/WgXk44nqcI0J
I am able to build the code using the make tutorial for pixhawk but failing whenever i start using the arduino development environment.
Here are the details:(also attached the config.mk for reference)
$ make
HAL_BOARD=HAL_BOARD_APM2 HAL_BOARD_SUBTYPE= TOOLCHAIN=AVR EXTRAFLAGS=-DGIT_VERSION="eebd32f3"
building /tmp/ArduPlane.build/ArduPlane.cpp
%% ArduPlane.cpp
%% ArduPlane.o
avr-g++.exe: error: /tmp/ArduPlane.build/ArduPlane.cpp: No such file or directory
avr-g++.exe: fatal error: no input files
compilation terminated.
C:/Users/Vayu/Documents/GitHub/ardupilot/mk/board_avr.mk:194: recipe for target `/tmp/ArduPlane.build/ArduPlane.o’ failed
make: *** [/tmp/ArduPlane.build/ArduPlane.o] Error 1
