Using the latest mission planner and arducopter 3.4 rc1, when using the geo-ref tool to geo-tag my images mission planner gives me an error “error reading log”.when I try to pre-process the log. I am using the same workflow that I always have and am a little bit stumped as to what is wrong with the log. I do get large logs, about 400mb (20 mins of flight) when converted to *.log as I have arducopter log almost everything. This hase not been an issue in the past but am wondering if it is now. I have used notepad++ to examine the log file and everything seems how it should be.
If the problem is the large logs causing mission planner to error, can someone provide me a link or some info for what I should be logging or some insight on what parameters I can manually remove from the .log with a text editor like notepad++ while still allowing mission planner to geo-tag the photos? I tried to edit the log with just leaving that cam and trig messages but it did not like that either.
Thanks for your help!
