When I try to update MP I get an error:
"Update Failed file downloaded does no match hash"
Is this is known issue?
It’s happened to me several times. Seems if I wait hours or overnight, the update progresses normally. Might be a server problem. If all else fails, remove and use msi install.
this is usualy cause buy proxy servers or similar. wait a while and retry.
I’m still having the error message. I can update other computers on the same network. I have updated this computer many times in the past.
I guess I’ll just uninstall and reinstall.
When you do, wipe out the whole folder where the program was on your HD. Save any logs or mission plans though. Did you try .msi file?
I just tried the .msi file and it worked fine. Then I updated to the beta through MP and that worked.
