I am looking to try the new VTOL-quicktune LUA script. I followed the instructions and put the script on the SD_Card and set the SCR_ENABLE=1. Upon rebooting the Cube Orange FC I am getting an error on the HUD. xpected symbol near โ<โ Do I need to increase the SCR_HEAP_SIZE to accommodate this script or am doing something else wrong.
The error message says "unexpected symbol near โ<โ. ". I guess the lua script is not properly copied and saved on the SD card, caused this syntax error? The script should look like this if opened by text editor.
I downloaded it straight from the link below and transferred it directly to the SD_Card from the cube. I wondered if the transfer process went wrong so I downloaded it a second time and saved it straight to the SD_Card. Same error both times.
