Error message received after install of Mission Planner
Received an error message after install of Mission Planner Ver 3.
Will not load mission planner sofware.
[quote][/quote]
The old mission planner was deleted to install the Ver 3 and I can’t install the old version back again.
Has anyone experienced this problem?
YumaMike
@YumaMike,
Take a look here on the DIY Drones MP Discussion Forum for similar installation issues: diydrones.com/forum/categori … orCategory
Regards,
TCIII Admin
This is the Error message.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ArdupilotMega.Controls.MainSwitcher.AddScreen(Screen Screen) in c:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\ExtLibs\Controls\MainSwitcher.cs:line 41
at ArdupilotMega.MainV2.MainV2_Load(Object sender, EventArgs e) in c:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:line 1506
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at ArdupilotMega.MainV2.WndProc(Message& m) in c:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:line 2060
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4241 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ArdupilotMegaPlanner10
Assembly Version: 1.1.4987.29718
Win32 Version: 1.2.73
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/ArdupilotMegaPlanner10.exe
System
Win32 Version: 2.0.50727.4235 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.1 built by: SP
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/log4net.DLL
System.Configuration
Win32 Version: 2.0.50727.4246 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.Scripting.ExtensionAttribute
Win32 Version: 2.6.1003.1
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/Microsoft.Scripting.ExtensionAttribute.DLL
Win32 Version: 2.0.50727.4236 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MissionPlanner.Controls
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/MissionPlanner.Controls.DLL
MissionPlanner.Comms
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/MissionPlanner.Comms.DLL
System.Reactive
Assembly Version: 1.0.10621.0
Win32 Version: 1.0.11226.2
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/System.Reactive.DLL
MissionPlanner.Utilities
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/MissionPlanner.Utilities.DLL
ProjNet
Assembly Version: 1.2.3432.30659
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/ProjNet.DLL
Transitions
Assembly Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/Transitions.DLL
IronPython
Assembly Version: 2.6.10920.0
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/IronPython.DLL
OpenTK.GLControl
Assembly Version: 1.1.0.0
Win32 Version: 1.1.625.30585
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/OpenTK.GLControl.DLL
GMap.NET.Core
Assembly Version: 1.5.5.5
Win32 Version: 1.5.5.5
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/GMap.NET.Core.DLL
System.Speech
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/System.Speech.DLL
GMap.NET.WindowsForms
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/GMap.NET.WindowsForms.DLL
ZedGraph
Assembly Version: 5.1.5.29715
Win32 Version: 5.1.5.29715
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/ZedGraph.DLL
OpenTK
Win32 Version: 1.1.299.38125
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/OpenTK.DLL
BSE.Windows.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Mission%20Planner/BSE.Windows.Forms.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
@YumaMike,
What version of Windows are you running? Looks like Vista. Do you have the latest SP installed?
Do you have Net Framework 4.0 or higher installed?
Have you tried installing as an Administrator by right clicking on the .msi and selecting Administrator?
Regards,
TCIII Admin
