When I hit the config/tuning button I get the following error message
Failed to process RC_FEEL_RP
System nullReferenceExeception. Object references not set to an instance of an object.
what fw do you have on your copter?
[quote=“phillyparty”]When I hit the config/tuning button I get the following error message
System nullReferenceExeception. Object references not set to an instance of an object.[/quote]
I get the same error today. I am using 3.1.2
how are you connecting? I cant replicate the issue
you cannot use control-t to connect.
[mf]Copter/3.1[/mf]
Hi everybody,
I am getting the same error, and i don’t understand how you resolved it. However, when i close the error window, the MP seems to work ok.
I have the FW 3.1.3 and the MP 1.3.0 and I use the connect button (up-right corner) to connect my apm.
i Have the Same Error with 3.1.1 FW
