Good day all.
I think there is an error in MP as to calculate/estimate flight time. See attached.
ID
Mission Planner Error.pdf (684.0 KB)
Good day all.
ID
any chance you can do a control-s and post that file here?
Hi
Thanks for quick response. yes I have posted the files at different flight alt below.
I changed extensions to .txt as .grid would not be accepted. I hope it works.
Thanks
ID
Mission Planner100.txt (2.1 KB)
Mission Planner110.txt (2.1 KB)
Mission Planner120.txt (2.1 KB)
Mission Planner140.txt (2.1 KB)
Mission Planner150.txt (2.1 KB)
Mission Planner130.txt (2.1 KB)
the bug looks like if its over 24hours.
fixed here
Thanks!
So latest version available for download? I see the last one was loaded up on the 9th Dec.
Thanks
ID
latest beta will have it.
Thanks you very much. I will give it another try.
Oops, I never installed beta version before, it seems there is no installer. Is this portable version I suppose?
ID
goto help > update beta
I’ve been seeing this issue as well. I am on version 1.3.56 build 1.3.6672.30243, which I just updated this morning. I just did the beta update which is build 1.3.6694.6400 and the issue is there as well. I’ll upload the .grid file.
make sure you home location in flight planner is correct, is my first guess
Perfect - that was exactly the issue. Thanks for the quick reply!
