Now, because you do not want to merge MisRelDec it to master, you want to create a local branch. As a simple rule don’t mess with master, master should always track the upstream master, that makes things easier. So:
If that is working fine and you want to update your PR to ardupilot, then you first need to locally delete your MisRelSep branch using gitk --all
And after that rename the MisRelDec branch to MisRelSep
and finally to update the pull request git push -f origin
And after that gitk --all on your local machine should be very clear. with everything in the right place.
The define of OSD_PARAM_NONE you can find on mavlink-master in ardupilotmega.xml - but sorrowly not in my repo.
Maybe you have forgotten the “git submodule update --recursive” before “git push origin”?
Edit: I tried that in a MisRelDec_PlayCopy of MisRelDec, but with no success.
In the meantime I noticed that the cleaned commits you made are probably not on my local yet?
(I didn’t completely understand that, but because we did a fetch/push instead a merge that could be ok?):
Many thanks again for your support and energy you give in here, Amilcar - I hope you will get it.
Edit 02.01.2021:
After a second rebase of origin/master and “git submodule update --init --recursive” the submodules seem to be updated (Submodule path ‘modules/mavlink’: checked out ‘d8cad47bb3e4ecf21ae631e492e9643cd063cb8c’) and the build of master is running without error.
Then I tried to checkout MisRelDec_PlayCopy and rebase also, but I don’t understand and how to solve the CONFLICT (submodule):
And I have an additional question, for that I could not find an answer in git tutorials: What will that “M…”-line tell me? I guess “be careful, the submodules are not fitting”
fyi here is the error I’m getting when I try to build MisRelDec_PlayCopy:
