[Errno 111] Connection refused sleeping
I’m getting this error on Ubuntu 18.04 running ArduPlane with sim_vehicle.py when the script tries to connect to the tcp for mavproxy
However I’m only getting it on one user. When it works for one user, it looks like this, before continuing successfully:
Connect tcp:127.0.0.1:5760 source_system=255
Failed to load module: No module named adsb. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Log Directory:
Telemetry log: mav.tlog
MAV> Waiting for heartbeat from tcp:127.0.0.1:5760
However, running the same commands as another user (the folder with all the python has open wx privileges), it throws an error when trying to hit that tcp, like this, before crashing:
Failed to connect to tcp:127.0.0.1:5760 : [Errno 111] Connection refused
SIM_VEHICLE: MAVProxy exited
SIM_VEHICLE: Killing tasks
Any ideas what’s up?
did you solve it yet, getting the same problem
I’m currently having the same problem on the ubuntu 18.04 on WSL2, let me know if you have this figured out. Though I am using arducopter, but it’s possible the solution could be the same.
Hi there,
got this this error once after a while after sucessfully starting ArduPlane/SITL/MAVProxy, but then playing with the parameters via MAVProxy. The error message is a bit misleading and the cure is quite simple.
ArduPilot always saves the latest (possibly messed up) parameter set in a file eeprom.bin in /home/user/ardupilot/ArduPlane. After getting the error it just helps to delete the file eeprom.bin.
The file is always recreated after starting up with new default values, that then should work again.
Since eeprom.bin is created for each user it is obvious that also the error depends on the actual user.
