Energy consumption
Hi all,
When simulating the aurducopter, I would like to check current /energy consumption, but not sure about the units? the vertical axis shown amps/hr? and what are the units here for energy consumed?
Any help will be greatly appreciated, thanks much
ArduCopter at the present time does not have a direct energy calculation. I use the logging functions in my Castle ESC’s for that. With the logs from Copter you would have to use mAh or amp-hours, which is not energy (in watt-hours). But the watt-hours could be calculated by taking total amp-hour consumption times average voltage.
You could update your APM Planner2 application for Ubuntu to 2.0.25, which is the latest. For some reason the latest on the firmware site is only there for Mac OSX. I have a build available for either 32 or 64-bit Ubuntu 16.04 here. If you are running an older version of Ubuntu then stick with what you have, as there will be dependency issues.
https://drive.google.com/open?id=0B5oLpNzxih4tSzJOUFpIZ1FZWk0
2.0.25 has much enhanced graphing for logs.
Chris,
thanks much for your response. So, what data the logs from Copter use to plot the energy consumption graph? thanks mcuh
If you want to graph energy consumption I would use amps x volts x hours (watt-hours). For instance an amp load of say 20 amps average @ 25 volts average for .5 hours would be ~250 watt-hours.
