running Arduplane V4.0.5 in Mission Planner 1.3.70 build 1.3.7277.34800 , I cannot see the checkbobx that is usually used for enabling compasses. In the attempt to enable compass i set Compass_enable=1 in Full List Parameters, but I have no evidence if it is really working or not.
Has maybe this feature been removed ?
I further checked in HW ID panel the list of devices_ID. I see that all Compass_Dev_ID are zero although set variables “Compass_enable=1” and “Compass_use=1” in Full List Parmeters.
Checked wires and connection on the board (Matek F405 wing), all seems good.
GPS sees 14-15 satellites indoor.
Nevertheless Compass cannot be calibrated: using Live Calibration, no white dots appear and no samples are collected.
Because there is no such checkbox ?
Compass is enabled when it detected and the driver is loaded, then you can select “use compass” checkbox to enable use of that compass. The compass_enabled should be 1 by default, and you should not change it unless there is a good reason, then you have to do it in the parameter list.
Edit : The compass enable checkbox were removed back in december.
Just for clarity I enclose the picture above with the red area where i supposed to find the checkbox i’m talking about.
As i questioned at the end above, you confirm that the feature were removed.
I was not aware of this.
The reasoning is simple : The only place where a user would want to disable the compasses is when doing non-GPS navigation and the wiki setup guides specify to set the MAG_ENABLE parameter to zero (like here) so we don’t need any easy-to-use checkbox for the 99% of users who are not doing non-GPS navigation
