I am writing code in my custom ground station to upload waypoints, set the current waypoint, and download the geofence from an APM2. I found docs for uploading waypoints (qgroundcontrol.org/mavlink/waypoint_protocol), and I found out how to set the current waypoint (using WAYPOINT_SET_CURRENT or MISSION_SET_CURRENT), and was therefore able to get everything working except for downloading the geofence. Since I couldn’t find any documentation on how to do so, I looked at the code in Mission Planner. This is my interpretation of the protocol, implemented in FlightPlanner.cs in the MissionPlanner src repo
- Set FENCE_TOTAL parameter
-------------- requires that you request the FENCE_TOTAL parameter and get the param_value in order to fill out a PARAM_SET message with the proper param_value - Send Fence Point and receive Fence Point, make sure they match, repeat until finished
I have not yet implemented parameter setting functionality so I have yet to try the above, but I have some speculation on the operation. What I think happens when you set the FENCE_TOTAL parameter is that the APM begins its protocol for receiving the geofence. I haven’t taken a look in the APM code so I’m not sure, but there must be a trigger since when I just do (2.) without having done (1.), when I receive fence point 0 it is not the same as the fence point 0 that I just sent over.
Tl;dr How do you implement the geofence upload from GCS->APM?
