ELRS link stats problem [SOLVED]
I have enabled AP_OSD_LINK_STATS_EXTENSIONS_ENABLED in my SpeedyBeeF405WingMini build (ver 4.5.6 stable). But on OSD(Walksnail via MSP DisplayPort) they don’t look right(fonts installed):
in MP it is setup like so:
Problems:
  1. No TX power value “–”
  2. RSSI is not scaled right - it should be -13, but I get -1
  3. RX antenna and SNR doesn’t have icons
My params are here Arduplane_osd_issue - Pastebin.com
What am I doing wrong?
Thanks
I think, you must load the newest font files from e.g. sneaky-fpv to have all the additional icons
Thanks. I’ll try it soon.
And what about no power values and wrong rssi? Do I need any special params enabled for it?
It’s analog OSD icons.
Fonts update helped with missing icons. Thanks @jreise-d !
If anyone stumble upon this post later - here is the link to updated fonts from SneakyFPV
Now just to fix the TX power.
@lida2003 What do you mean? I’m using digital osd.
what you saw on MP is analog OSD icon.
Try to uncheck “Use Link Quality for RSSI with CRSF” in RC_OPTIONS. Here ist my setting where rssi icons are displayed correctly.
My icons are fine after updating the fonts.
UPDATE: I managed to fix the power value not showing.
As per ExpressLRS documentation - a power update is received from the transmitter, which is only available in Wide Switch Mode or any FullRes mode.
