Normally this happens when the flight controller runs out of memory. I didn’t see anything in your params that stood out. Did you build this yourself using the custom build server?
Yes, I build it myself based on 4.4.2.
And I have found some thing wrong with config.This board has two replaceable IMUs (MPU6500/MPU6000), but the direction is different.
The most important thing is “MPU6500 is displayed as MPU6000 in MP”, which took me quite a long time for the IMU configuration of my Aocoda-RC F405V2 Mark4 7“ PNP
— Update
Mission planner doesn’t have DEVTYPE_ACC_MPU6500 type. If we add MPU6500 type 0x14 for distinguishing MPU6500, then it would be nice.
Hi. I also have an Aocoda-RC-F405V2 MPU6500 board, I would like to flash it to Ardupilot. Could you please share your results on firmware development. Maybe you found some third-party firmware or finalized your own. Maybe there are older firmware for this board. I would be very grateful for any answer. Thank you!
Well, it’s configuration steps for F405V2, which you might wanna take a look, but it’s Chinese. The most important thing is to set INS_ENABLE_MASK properly, or CPU might be very high, which should be around 30~40%, i don’t remember exactly.
