Hi all,
There a weird issue going on during compass calibration: on Mission Planner it draws out an egg, a quite long one. This happens even when i try far out on the field or in the house with the fc and gps/compass is on the table.
I know how it sounds at first, because the earth also not perfect globe, but not this much i believe
What i can’t understand at, all that this should be already a replacement set. The original was replaced because this issue well besides others.
What can cause it? Which logs should i check?
Thoughts and suggestions welcome!
