Edison cann't connect pixhawk2!
Hi,all
I installed the Edison module into pixhawk2, and flash apsyns-edison image to Edison, now I can run linux in Edison successfully, and I have set the parameters:
SERIAL2_PROTOCOL = 1
SERIAL2_BAUD = 921
LOG_BACKEND_TYPE = 3
but if I run command below:
spsync@apsync:~/dronekit-python/examples/vehicle_state$ python vehicle_state.py --connect ‘/dev/ttyMFD1,57600’
it print below:
Connecting to vehicle on: /dev/ttyMFD1,57600
link timeout, no heartbeat in last 5 seconds
I am not sure that baut rate, so I change the baut rate, and try another command below:
spsync@apsync:~/dronekit-python/examples/vehicle_state$ python vehicle_state.py --connect ‘/dev/ttyMFD1,921600’
unfortunity, the same error," timeout"
I am confused about it, woule you please give me some hints, thanks in advance…
Gavin
parameters:
SERIAL2_BAUD = 921
it print below:
You can’t sensibly connect directly to the serial device, as cmavnode will
be holding the serial device open.
cmavnode relays onto various other ports you might try opening instead -
try “–connect udp:localhost:9000”, perhaps. See cmavnode.conf for other
ports.
Hi,peterbarker
  thanks for your reply. I tried to run the command:
python vehicle_state.py --connect udp:localhost:9000
it print as below:
Connecting to vehicle on: udp:localhost:9000
APM:Copter V3.4-dev (c9bd67e4)
PX4: 44574c48 NuttX: 579e82d4
Frame: QUAD
PX4v2 002F002E 3435510A 38393730
Exception in message handler for HEARTBEAT
mode 0 not available on mavlink definition
I think this log indicate it’s unnormal, so what can I do
I see the cmavnode.conf file, the content as below:
[aseriallink]
type=serial
port=/dev/ttyMFD1
baud=921600
sim_enable=false
[to_mavproxy]
type=udp
targetip=127.0.0.1
targetport=14655
localport=14656
sim_enable=false
[to_dflogger]
type=udp
targetip=127.0.0.1
targetport=14555
localport=14556
sim_enable=false
[to_14550]
type=udpbcast
sim_enable=false
bcastport=14550
bcastip=10.0.1.255
bcastlock=1
[spare_out_0]
type=udp
targetip=127.0.0.1
targetport=9000
localport=9006
sim_enable=false
[spare_out_1]
type=udp
targetip=127.0.0.1
targetport=9001
localport=9007
sim_enable=false
[spare_in_0]
type=udp
targetip=127.0.0.1
localport=9010
sim_enable=false
[spare_in_1]
type=udp
targetip=127.0.0.1
localport=9011
sim_enable=false
thanks a lot!!!
try 921000 as your baudrate, as this is what you have everything else configured for.
Nah, sorry, that’s normal. We’re still discussing potential fixes for the
mavlink-heartbeat message stuff. Gory detils are here:
You’re certainly connected to your vehicle…
hi, james, thanks
I have tried the bautrate 921600, unfortunately, have the same log, link timeout!
