Hi all
I have a an X8 frame where arms can be replaced and become an X4.
X8 motor configuration has been done following ardupilot tutorials therefore the correct motor sequence become A-C-E-G for the upper motors and B-D-F-H for the bottom motors (as described here http://copter.ardupilot.com/wiki/connecting-the-escs-and-motors/)
Now, I installed the X4 firmware , I would have expected the correct sequence of the motors. so clockwise A-B-C-D, instead C and D are switched.
what would be the best configuration ? I would like to avoid to unplug motor PWM cable to correct motor sequence, so what would be the consequence of using the X8 configuration with just 4 motors?
…obviusly autotune must be redone
thk
