Servers by jDrones
Eagle Tree OSD Pro connect to Pixhawk?
It is possible to connect
this Eagle Tree OSD Pro
if so please any circuit diagram …
Thank you in advance for your answer.
Regards
birdeyevtol
That particular OSD is not compatible. Sorry!
There are a few mavlink compatible OSD modules on the market (minimosd and alceosd for instance), plus native support for a number of autopilots with built in osd chips.
Hi James,
I did not want to buy it, I got it at home,
so I wanted to use it. If it’s not compatible, then I’m clear that you need to buy the right one else. How do you write them a lot.
Thank you for your response.
Best Regards
birdeyevtol
There’s some info here: http://ardupilot.org/copter/docs/common-osd-boards-on-screen-display.html
Servers by jDrones
