Dualway esc not receiving signal from pixhawk
Hi;
I can’t run this esc with pixhawk 2.4.8. Esc can control two motors. Plug the signal ends of the Esc into the pwm 1 and 3 sockets on the pixhawk. My remote receiver is connected with ppm encoder. I can see the remote controls on the mission planner. But I can’t start the motors. Esc protocol selected is normal
note: When I connect Esc, motors and radio receiver directly, the motors run in the right directions. When I connected the Pixhawk in, the motors don’t start.
What could be the problem?
Post your parameter file.
rover.param (13.4 KB)
Pick Rover for FRAME_CLASS. Have a Safety switch connected and you are arming it? Best way with Rover is to set an arming switch.
