I have a North Dual RTK receiver that gives me fixed RTK positioning + NMEA HDG sentence with true heading based on the dual RTK antennas. Works good but my question is what does Rover 4.2.2 expect ? Does it expect true heading to compute the track required between waypoints so must I calculate and provide magnetic ? Or pass true via the HDG sentence ?
The final configuration of this project is a tracked vineyard robot (35 hp, 1500lb). I have been working on it off and on for 5 years (more off than on!) and it keeps getting more functional.
I use DualRTKite from North Surveying in Spain. It has 2 antenna feeds and usse a North ground station with UHF radio link to get RTK corrections at 20Hz. It does the trig math and outputs the true heading of the rover in NMEA HDG sentence. I tried it sending either mag or true and I think that the waypoint track is computed relative to true North so true north appears to be the needed heading.
ardupilot handles NMEA. The whole setup works quite well. maybe 10 cm drift. The next thing is to improve Rover tuning. I can get it to follow a path but still working on getting all the tuning params right so I don’t get jitter and better xtrack accuracy. Any tips from anyone appreciated as the documentation is a little sparse.
BTW: I think the skid-steer mapping in ardupilot is not great. I have implemented my own, and am testing it side-by-side.
